Looks just like my Forge one ... but different colour. :biggrin:
Dave
Printable View
The packaging is identical to the forge ones too :crazy:
hey how much did the FMIC set you back Neil? (incl piping etc)
I'll bet back to you on that Dave, I just have the core at the moment, I'll be getting all the piping done custom in stainless. That will be the most expensive part of it...
I'm considering a change of direction slightly.
To date the parts I have include:
- K04-023
- S3 injectors
- S3 manifold
- S3 dump (on it's way)
- 4 Bar FPR
- FMIC core
- TIP (on it's way)
- Silicone Hose Kit (on it's way)
I still need to get all the bolts, gaskets and oil/coolant return lines wich is going to be another $700 plus. Ialso have the expense of tuning and also the labour involved. I've got the coin to do it, but I want to spend it wisely.
I'm thinking I might just do the FMIC for now (it's pretty universal) and save a bit more and get a quaife or a pelequin LSD plus an ECS stage 1 clutch sent also before I embark on this little build. The more I read into it, the more I'm begining to think my standard one will not last long and since we'll already be under there, I might as well do the LSD now also. Obviouslty this is a significant added expense and has completly blown out my budget but I'm thinking it might be best to do it once and do it right.
Or, I might just do the clutch for now and hold out for a while and do the LSD at a later date.... Hmmmmmmmm... Decisions.
