Results 1 to 1 of 1
Thread: MKIV FAQ and HOW TO THREAD
    Jul 2005
    Maroubra, NSW
    We will try to keep this thread up to date with FAQ answers and how to's for the MKIV.
    Please contact an moderator if you feel something should be added to this list or needs to be stickied!!!
    Golf MK IV -The Story - Thanks to DeemoIII
    Bora - The Story - Thanks DeemoIII
    Timing belt replacement - Thanks to Bug Racer
    Eurovox Headunit Wiring Diagram
    How to check for perished rear brake lines - Thanks gtimkv
    MKIV GTI 1.8T Engine Codes
    SMIC GTI 1.8T - Thanks gpk_gti
    VWVortex MKIV FAQ and How to thread - (off site)
    Differences between GTI models, and simple mod suggestions - Thanks Fuzion
    Thermofan Failure and Repair Suggestion - Thanks Bora Sport
    Aftermarket Install of iPod compatible Head Unit - Thanks Dancet
    Boost Guage DIY Install - Thanks Dancet
    TT Style Vent Guard Mod (for 1.8t's) - Thanks Fuzion
    TIP Installation Instructions Installing a FORGE turbo inlet hose - Thanks gpk_gti
    Diverter and Blowoff Valves - The differences - Thanks Fuzion
    Exhaust discussion (dump pipes, cat etc) - Thanks Shami and h100VW
    Air Box Mods - Thanks gpk_gti and Fuzion
    Interior Mods - Thanks Fuzion
    Which oil do you use? - Thanks Dancet
    Fuel gauge stuck on full? - Thanks Simex
    MKIV Parts thread - Thanks gpk_gti
    Faster than normal idle - Thanks silverdovegti
    Service Intervals 1.8t & 2.0 - Thanks 99gti
    Repairing scratched interior plastics - Thanks Pepper_Marsh
    reset service light and accessing climatronic readout - Thanks gpk_gti and YellowDieselGolf
    Wheel size and off set - Thanks evorobin
    CAI setups-Thanks 99gti & Sierra055
    rear wiper mod-PICS - Thanks VWEAPN
    VW aproved oils - Thanks Didz
    Pankcake pipe replacement - Thanks 99gti
    Rear sway bar instalation - Thanks Sierra055
    Replacing aero wipers blade - Thanks No457 Snowy
    Tutorial: Fix your Mk4 Aircon / Heater cluster lighting - pics - Thanks to Stan
    OEM R32 Wheel Alignment Settings - Thanks to Quozl
    A source for the dreaded door microswitch for failing doorlock's - Thanks to Graeme86
    MKIV Door Locks Explained Why You're Having Problems!!!
    Control arm bushings and wheels bearings... A how to - Thanks to kaneda & Mr. JLT
    DIY: Broken Mirror Switch knob fix
    http://www.vwwatercooled.com.au/foru...ion-91912.html Thanks swainey32
    Thanks to all of those who have taken the time to write up these mods, it makes it much easier for people to DIY when there are some helpful articles such as these.
    Cheers all, keep them coming!
    Last edited by JustCruisn; 11-04-2016 at 08:05 PM. Reason: Fixed VW Vortex DIY Link
    2015 Multivan Highline
    1969 Sunbeam Imp Sport 930cc
