Results 1 to 6 of 6
Thread: Wheels for the Bora 4Mo
    Apr 2011
    Have seen lots of Subaru Liberty GT wheels around...cheap.
    Don't know much about wheel fitment and a search of the forum tells me they might fit.
    I think the PCD is the same, but the offset and bore?
    Will they only fit with spacers/adapters etc?
    Sep 2009
    I cant remember the bore but the stud pattern is 5x100 and depending on width a +35 fits nicely. I think bore is 57.something but i honestly cant remember. My current rims were on a subey before and they sit nicely being +35, also happens that the hub ring is the correct size but i'm not sure if the place i got them from swapped them out or not.
    Apr 2008
    57.1mm centre bore is correct for a Mk4. You will need hubcentric rings to fit Subie wheels.
    As noted, depending on width, offset on the Mk4 ranges from about +32 to +38.
    Jan 2009
    blankedy
    Find out the Liberty bore, see if there are Spigot rings for the fitting size. Have a look on EBay UK site, one seller sells just the spigot rings, only about $10 for a set. They may be able to sort you out.
    Apr 2011
    Thanks. helpful as always.
    i thought 5x100 subaru wheels had a 56 something centrebore? There for not actually fitting over the vw hub...
    Depends on the wheels but usually offset is more like +50, if thats the case you MAY run into rubbing issues on your shocks etc
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
