Sorry mate can't help with tooling.
What you going to run on rear as your BBK ?
Printable View
This plus brembo 1 pot ebrake calipers and adapters are good to go now just want to double check with the brake dust sheild and then I can get some new ones cut.
http://www.vwwatercooled.com.au/foru...PB040124-1.jpg
So I'm on revision 4 of the mounting bracket (thanks Steve for the milling)and everything lines up and bolts up correctly, So now I can get some new brackets laser cut out of one piece of metal instead of 3. Now I'm waiting for some 315mm rotors to show up. So in the mean time I need to bead blast the brembo ebrakes and rebuild them and then paint all the rear brakes.
Got another set of rear brake lines fabbed up so I can run them from the 4 pot rear caliper through the rear trailing arms to the hard lines. Ohh and the shop foreman approved the upgrading in braking.
http://i58.photobucket.com/albums/g2...1/P3020290.jpg
http://i58.photobucket.com/albums/g2...1/P3020288.jpg
Nice jay , hydraulic handbrake?? Ohh maybe not as there probably plumbed in line with the main pots.
yeah what on earth is that for, some ghetto security mod?
Was thinking that , would be easy to do , get on it. Lol
http://www.vwwatercooled.com.au/foru...IMG_5398-1.jpg
You know you want it.
Looking good man.
A hyd hand brk umm………….
