Results 1 to 8 of 8
Thread: 2 Faults with my car. Lock and Computer
    Jan 2009
    Anglesea,victoria
    Hey guys.
    Just picked up a 2000 model golf and its great although there are 2 problems with it.
    Firstly the lock on the drivers door. I am unable to turn the key in the barrel of the lock and i cant lock the door from the inside. To lock and unlock i have to goto the passenger door and turn the key in there and it works fine, quite annoying though. Also tonight the drivers interior door handle pulled out from the trim a little bit, is this connected to the other problem in any way?
    Secondly i believe that my on board computer isnt working. Am i meant to have some kind of read out of fuel consumption and suck between the speedo and rev meter in the little rectangle in the center of the guage cluster? if so nothing is appearing in there when the car is running.
    Is there something im meant to be pressing to turn this on or is it an option i dont have or is it busted or something else all together?
    Cheers guys.
    Mitch.
    The computer, if fitted, is controlled by the end of the right hand stalk, no buttons on there = no computer.
    Not sure about the locking but could be wiring. A strip of the door panel would be a good idea.
    Jan 2009
    sydney
    hi
    if the door barrel spins around and around or the lock is tight to move, you will a new door barrel assembley, the carrier breaks and it wont turn the lock.
    with the on board ecu, if there are no button on the end of the stalk there is no on board, also some had a reset button on the bottom of the stalk which turned the screen on and off, but i not sure what model had it
    cheers
    Jan 2009
    Anglesea,victoria
    I'll outline the problem better. When i insert the key into the drivers door lock, i cant turn it clockwise at all. If i turn it counter clockwise it will rotate to the locking position but it wont lock the doors or raise the windows. It feels as if there is no contact being made inside the lock compared to the passenger door.
    Im going around to a ex volkswagen mechanic's place tonight and we will suss it out. he had a quck look and thinks we might be able to fix it.
    But is there anyone else who has had this niggle? how did you fix it all up.
    Sep 2008
    Launceston
    I have a 01 mk4 gti with the cruise control stick, but no read out. Should i have a read out?
    Sorry to jack your thread mate
    Sep 2007
    I think it was only the MY02+ cars that had the half height MFD's
    Aug 2007
    Perth WA
    Quote Originally Posted by ntails View Post
    No probably not the MFD controls are on the right had side stalk with the wipers.
    '04 BMP MkIV R32 #144
    search getnew
    Jul 2007
    Brissy
    Quote Originally Posted by sierra055 View Post
    Yep from my research that is correct.
