Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: MK4 GTI Misfire
    Oct 2005
    Melbourne - Greensborough
    MK4 GTI Misfire
    Hey all,
    Got a MK4 GTI thats not firing on 4 cylinders, we changed plugs and coil packs, thats not the problem. Is there any other common problems that it would be? Thought i would ask before i get deeper into it.
    MK4 GTI (KO4, GIAC)
    VW Kombi Ute 2ltr EFI
    Audi 90 20V Quattro
    syncro Guest
    Coil packs.
    Camden, Sydney
    H T Leads?
    syncro Guest
    Quote Originally Posted by Golf Loon
    H T Leads?
    You mean connectors? The leads last forever. (They're copper)
    You need to scan it with VAG-COM the amount it can tell you is amazing.
    The only thing I have heard that fails all the time apart from coil packs is the water temp sender. Check you have a green one fitted the black ones are the duff ones.
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by h100vw
    Vag com doesnt pick up misfires on a mk4 Golf .
    The ignition module is on the side of the airbox near the MAF . Disconnect it and clean the 2 plug terminals and put it back in . Sometimes that fixes the problem . If it doesnt work try and find another one to swap it with
    Oct 2005
    Syncro- Already changed coil packs, thats not the problem.
    Golf Loon- Are you getting this mixed up with a 1.6/2ltr? Unless you mean those leads to the coil packs.
    H100VW - Already changed the black temp probe to green a while back, I will scan it tomorow when i have time to look.
    Bug_racer - I will try that.
    Thanks for the info guys. I will look at it tommorow when i have time, i just thought there might be a common thing apart from coil packs.
    MK4 GTI (KO4, GIAC)
    Audi 90 20V Quattro
    syncro Guest
    Can you isolate any particular cylinder?
    Oct 2005
    i havn't even looked at the car yet, i will tommorow though.
    MK4 GTI (KO4, GIAC)
    Audi 90 20V Quattro
    Quote Originally Posted by Bug_racer
    Is that a feature of the NA ECU cos I have seen it on 1.8Ts.
Similar Threads
  1. Mysterious Intermititant misfire. :?
    By ScienceVR6 in forum Mk3 Golf & Vento
    Last Post: 19-02-2007, 07:28 PM
  2. Misfiring weber conversion
    By black betty in forum Mk1 Golf
    Last Post: 06-08-2005, 07:48 PM
