Results 1 to 10 of 35
Thread: Bora Repair and sourcing parts...
Threaded View
    Jan 2009
    Caringbah, Sydney
    hello,
    Car : VW Bora 2004 2.0 stock standard. 110 000 km. purchased new.
    wifes car is slowly packing it in and she hasnt ever had a proper service except for her dad changing the oil every so often. I think all thats been done is a new Gearbox and a new clutch! i dont know what she was doing to it!!
    I NEED ADVICE...I think ive narrowed most of it down. Am i missing anything, or is there anything I should be trying?
    first mech. problem is the VERY loud ticking ( lifters?!?!). I think its the lifters. when I got a hold of the car i added oil and the ticking quietened down. then after a while it returned. i then after researching decided to run ATF through the engine for about 30 mins at 2500 revs, then flushed the engine and returned to the regular oil she and her father demanded.( mobile 1 5w 50 I think). the ATF treatment was great.. it almost seemed to have sorted the problem.. then about 200 km or so later the noise slowly returned. Im guessing new thinner oil maybe or maybe the lifters need a clean/replace!? Im thinkin its a bit thick... the oil not my wife!
    at the same time..
    • shocks are bottuming out (front)
    • brakes and DISCS are close to being due
    • timing belt needs done.
    • while im here might as well do all the filters considering no one has ever looked under there.
    • replacement lifters, im guessing if all else fails.
    all of this is getting pretty expensive as far as I can see.. which is why i thought I might take it upon myself to be a mechanic. Ive got the bentleys and Ive been researching for a while now so as not to F*** it up!
    main question is. whats a cheap place get parts?
    below is my parts list so far
    From www.Germanautoparts.com
    • VW G12 PLus PLus x 2
    • Oil filter, package of 10
    • Valve cover gasket, rubber
    • Gasket, upper intake manifold
    • OEM gas charged Strut. Front
    • OEM gas charged Strut. Rear
    • OEM discs front
    • OEM discs rear
    • OEM pads Front.
    • OEM pads Rear
    From www.MJMAutohaus.com
    • Meyle Cabin Air Filter Charcoal
    • OEM Fuel Filter
    • OEM VAG Engine Air Filter
    • OEM VAG Lifters, Set of 8
    • Victor Reinz Gasket Sealer
    • Timing Belt Kit "PLUS" w/ strech bolts
    • Suspension "PLUS" Rebuild
    I rang barloworld and the people at Volksbahn and I looked for other aussie stockists but the prices are pretty high or they didnt have what i need in stock.
    I guess more than anything I need to know that Im doing the right thing...
    and maybe a little bit of moral support... or something.
