Results 1 to 6 of 6
Thread: Bora gear knob question
    Jan 2008
    brisbane
    Hi all
    I would like to replace the gear knob on my Bora V5. I have tried twisting it off anti-clockwise but the whole boot moves with the actual gear knob. Is there a trick to it that can be explained to me?
    Cheers Matt
    Sep 2006
    If you lift the boot over the gear knob you can see a collar that holds the knob on the shaft I think this collar needs to be sacrificed to get the knob off
    Jan 2008
    brisbane
    Thanks Sukebe
    How do I get the gear boot over the gear knob?
    Matt
    Sep 2006
    The plastic trim has clips in the dash, unclip them and lift the gaiter over the knob (it will still be attached but you will be able to access the collar
    Jan 2008
    brisbane
    Thanks Sukebe
    I'll have a crack at it on the weekend.
    Gladesville, NSW
    Yep, you are supposed to replace a clip but I did read a post where someone worked it off slowly to preserve it.
