Results 1 to 5 of 5
Thread: Faulty MAF Sensor?
    Mar 2009
    Faulty MAF Sensor?
    Hey guys,
    Just wondering if anyone here has some advice or experience of the issue I'm having.
    For about the last 6 months, my car (2002 MK4 2.0 litre petrol) has gone through 5 or 6 phases of running really badly. These phases usually last 2-3 days at a time and then go away.
    Symptoms are rough idle (using 3.2L/Hr of fuel when idling. Normally 1.3L/Hr)
    Very bad economy (350km from a tank as opposed to 550-600km)
    Strong fuel type smell that enters the cabin
    Sluggish acceleration at times
    Through a bit of research here and elsewhere, I've found the cause could possibly be a faulty/dirty MAF sensor. To test this, I unplugged the MAF and drove the car for about 50km. It idled at around 1.8-1.9L/Hr and generally seemed to run a lot smoother. At a couple of lights though, it ran up to 3.1L/Hr again. The smell was far less prominent.
    Does this mean that the MAF is definitely on the way out, or could there be other things at work here contributing to the problem?
    If it were the MAF, any recommendations on where to buy one cheaply in Melbourne?
    Cheers guys.
    Scan with VCDS.
    Replace things based on what you find.
    Quote Originally Posted by Colvs View Post
    Hey guys,
    Cheers guys.
    Sounds like it could be a MAF, but there are other sensors or issues that can cause similar symptoms.
    As Gavin said, best to have it scanned
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2009
    Cheers for the replies guys. Now to find someone with VCDS to scan it for me...
    Mar 2010
    Lesmurdie
    Might have a bit of luck if you post in here. http://www.vwwatercooled.com.au/forums/f153/
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
