Awesome!
Does this use a DBW pedal?
All the loom was in place just needed the cruise loom from black plug under dash to wherever it ends up?
Printable View
Awesome!
Yep. No TB on this bad boy.
Wiring must be from the ecu in to the car already? I noticed on some petrol models the loom I got has an extra wire that needs to go to the ecu. Maybe that's a dbw vs cable thing?
This loom ran from the switch, to the rain tray, and a single wire to the fuse box for power. Fairly simple once I worked out which pin went where
That green cruise control light on the dash looks great. Glad that it all came together without too much hair pulling.
Yep so happy. Racked up over 400 miles over the weekend so was used a fair bit.
Due to the long rails I'm getting more space between the bars than the bora had. Coming in handy alreadyhttp://www.vwwatercooled.com.au/foru...924a3174-1.jpg
Sent from my HTC 2PZC100 using Tapatalk
Mighty handy that. I had to do something similar with my Caddy's roof rails and racks when bringing home a new solid core front door from Bunnings.
Bored of driving a stock car
Time to start getting all my good bits together.
280 and 232mm upgrade to 334 and 256mmhttp://www.vwwatercooled.com.au/foru...5fd413a6-1.jpg
Big brakes for a big brick
Yep. Will pull it up nicely and also slow it down a fair bit. Will just mean I'll have to make it faster afterwards
I thought mk4 wagons are rare in aus
Fixed (fingers crossed) gearbox leak and did a fluid change. After a 20min drive 3rd and 5th feel much better. http://www.vwwatercooled.com.au/foru...251475e9-1.jpg
Careful they are multiplying :P
