Results 1 to 10 of 10
Thread: RNS 510 in MKIV r32?
    Feb 2010
    Southeastern Victoria
    Hey guys just wondering if anyone has fitted a RNS 510 unit in their MKIV??
    Dec 2008
    Sydney/Canberra
    Good luck finding a hole for it.
    Seriously, unless you're into moulding new dash trims and making brackets, I can't see it happening.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2007
    Brissy
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Dec 2008
    Sydney/Canberra
    That's the Touareg version. Way different to the one normally seen in Golfs, Tiguans, Passats, etc...
    '01 Beetle 2.0
    Feb 2010
    thanks guys
    the Touareg version seems easier to fit in since its square on the corners and not rounded like the other
    ive looked at a couple of others it doesnt seem that hard so ill start looking at getting my hands on a Touareg RNS 510 unit
    Dec 2008
    Sydney/Canberra
    Let us know how you get on. I've got an RCD300 out of a Touareg that might find it's way into my partner's MK4. If not, I'll sell it.
    '01 Beetle 2.0
    May 2009
    North Brisvages
    Is that a MK5 R32 Wheel in the picture !!
    Would it not be easier to go Alpine or something similar or are you after OEM stuff.
    Only asking as thats where I'm stuck now OEM or jump in for after market stuff !
    Mar 2009
    Wagga Wagga
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by trickysimon View Post
    Thats a Mk6 Wheel Big M
    Yes the MkVI wheel looks nicer and has buttons on it, but in my opinion the MkIV R wheel is superior as it has a much thicker rim. A fat wheel triumphs all when it comes to looks I reckon.
    The issue with fitting an RNS system or any sound system or device is that from the MkV onwards everything runs on the CAN-Bus communications protocol whereas the MkIV ran predominantly on OBDII with a few systems running on CAN-Bus. Getting the whole lot to talk to each other is the real problem. Making them fit and wiring them in is the easy part.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Mar 2008
    Central Coast but currently living Bosnia
    just read that the person bought the bezzel for a caddy and cut it to size to fit in the mk4....
    thnx
    2010 Jetta 2.0l TDI 103
    2010 Passat CC 2.0l TDI 125
    2011 Passat 2.0l TDI 125
