Results 1 to 8 of 8
Thread: Rear passenger door wont open
    Hey guys,
    Couldn't find a thread relating to this problem,
    My rear left passenger door wont open on my 04 GTI, central locking works fine on all other doors. It is in the lock position and wont budge at all. Dealer said it needs new lock and part is around $350 plus labour!!
    Any one else have this problem?
    Cheers and sorry if already posted.
    Dec 2008
    sydney
    So you can't open it from the outside either.
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
    Nah, cant open from the outside either, I have young kids and need to get it fixed.
    Dec 2008
    sydney
    What do the inside and outside handles feel like? Do they pull freely or is there any resistance
    See if you can get the door card off without breaking any clips or the panel.
    First check the steel rod that goes from the door handle to the lock mechanism, they do break.
    lock pin could be faulty if the handle pulls freely.
    Try this How do you fix a rear passenger door handle on a MK4 VW Golf with child lock enabled so the door cannot be opened from the inside The handle pulls and clicks but nothing happens
    Opening rear door on MKIV VW Golf : handle broken, child lock engaged - YouTube
    Good luck
    Ducati 749
    Quote Originally Posted by VR6man View Post
    Good luck
    Thanks VR6man, will give it a go this weekend
    cheers
    Jim
    Jul 2007
    Brissy
    The locks on these cars are haunted !
    Way too expensive to fix and a pain in the ass to put up with.
    Normally the front locks go first.
    Good luck, keep us posted.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Dec 2008
    sydney
    You can always enter the car 'Dukes of Hazard' style.
    Yee-ha
    Ducati 749
    Good luck
    So I got the door card almost off, leaving the two bottom clips still in place and could reach inside and check the steel rod that goes from the door handle to the lock mechanism and its ok, the door handle works fine on the inside, but the outside handle pulls but does nothing. Not sure if its the actual handle on the outside that's faulty, but then again the central locking mechanism on the door could also be shot, ended up putting it all back together as I need to lock the car, as opposed to opening it and not being able to lock it...will give it another once over before taking it in I suppose, or giving 'Dukes of Hazard' a go...lol
    Thanks guys for the responses.
