Erratic Coolant Temp Gauge
Hi Everyone,
A while ago I posted a thread regarding what was normal in regard to the coolant temp gauge in my Mk IV (1.6)
I thought I had fixed the problem by cleaning the terminals on the temp sender unit....but the problem is back.
On most occassions, the temp gauge reads fine, but then the needle slowly drops away to read almost nothing on the gauge....and then for no apparent reason, the needle climbs back up to read normally. This can fluctuate like this all trip or it might read normally all day.
Any suggestions, is there a way of testing the sender unit, and if I were to decide to simply replace it, is there anywhere in Brisbane who sells VW parts other than the local VW Stealer
Thanks for your help
- You may not post replies
- You may not edit your posts
Forum Rules
