Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: RE: Exhaust / Quick Question
    May 2007
    Hi Guys,
    As the title suggests I have a quick question in regards to the Exhaust / Cat / Dump Pipe of MK4 GTI's 1.8L Turbo.
    - Is the standard dump pipe off the turbo (where the four bolts are) Mild Steel / Stainless Steel or Cast?
    - When people upgrade the exhaust system, do you also change the factory Cat? (I have been told that these Cats are Euro 4 and can not be replaced by just a standard performance high flow cat.) or do you not use a Cat altogether? (Is there legal issues with that???)
    Any help would be great!
    Glenn
    Aug 2007
    The dump pipes are cast and you must run a CAT of some sort. Cops are catching on to gutted cats these days with infra red heat guns. They will get a reading from the inlet and outlet of the cat and if theres no difference in temp, you get reamed.
    Nov 2006
    Quote Originally Posted by FknDubbin View Post
    $20,000 fine from the EPA if you get caught too!
    JC! Thats a bit steep! That'd get me a K04 upgrade and all the bits and bobs plus more and I'd probably be putting out more emmisions anyway
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    May 2007
    Thanks for the quick reply guys!
    Mar 2007
    sydney
    Quote Originally Posted by ope126 View Post
    i have apr dp 2.5" its sweet make sure you get a rhd dp no a cheap **** one from ebay
    mk4 the mods begin for round 2 hahahha
    Aug 2007
    doncaster, vic
    i also have a 2.5" and hi flow cat...no probs
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    May 2007
    Quote Originally Posted by DUB 20V View Post
    I am also looking to do a 2.5" dump pipe. However at this stage I am looking to get it custom made!
    May 2007
    Moonee Ponds
    What are the cops like towards butterfly valves like the varex ?
    Aug 2007
    What they cant find, they cant shaft you for. You just have to be smart about what you do.
