Fronts had to be done in 2 stages. Struts and springs, then the R32 knuckle swap.
Undo top mount nut - 60nM
Attachment 54099
remove sway bar link - 90nM, brake lines and abs wiring from the strut.
Attachment 54100
new links
Attachment 54101
Undo strut to knuckle bolt 60nM + 90' and insert knuckle spreader bit
Attachment 54102
Pulled the strut out, had to swap over the brake line/abs bracket. Litte bit of anti-seize inside the knuckle to stop the strut from seizing in there.
Attachment 54103
Attachment 54104
Done.
Attachment 54105
Quick comparison height wise
R32 EU v R32 AU
Attachment 54106
