Results 1 to 10 of 13
Thread: Has enyone else had this problem??
    Sep 2008
    Launceston
    When i turned my car off on saturday morning i jumped out a went to arm the alarm(viper, not factory) and it wouldn't turn on. I open the door and could hear a relay clicking like mad behind the fuse box. Put the key back in a tried to start the engine, nothing. After about a minute the relay stopped and i could start the car. For the rest of the weekend it was fine, then when i arrived at work this morning the same thing happened again. Over the last month a few funny things have happened.
    - Interior light not working when opening doors
    - Interior light not turning on when switching alarm off
    - And now the relay situation........
    Could all these be linked?? Faulty relay??
    Jun 2008
    Ringwood, Victoria
    Have you checked all your fuses? That's the easiest place to start, other than that, it is a MkIV Golf and they're notorious for electrical faults. I only bought mine because it came with a full 1 year warranty, i'm probably planning on selling it when that 1 year is up just in case.....
    Sep 2008
    Launceston
    Fuses should be ok as the interior lights work when you switch them on, just not when you open the doors or use the alarm.
    Its a MK4 GTI.
    May 2007
    Moonee Ponds
    Interior lights not working when opening the doors is something to do with the door lock switch module. I had mine replaced, I posted about it a while back.
    Should the lights come on when turning the alarm off ? Mine come on when unlocking the car or opening the doors but yours may be different ?
    Check the volts on the battery is good, relay clicking can sometimes be because there isn't enough power.
    Check connections on the alarm ? Or even better take back to the person who installed the alarm.
    Quote Originally Posted by ntails View Post
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Quote Originally Posted by gavs View Post
    I don't know why you have that conclusion, I've had no electrical problems at all with my Mk4 Golf over the last 4 years.
    Is the alarm installed recently ??? probably a dodge installation that caused your problems.
    May 2007
    Moonee Ponds
    The golf's electronics aren't the best but they are not the worst. Yes a few things fail but I think you will find that with all cars.
    You would be foolhardy to keep a car for a year in this current climate.
    Quote Originally Posted by RedMk2Gti View Post
    Jun 2008
    Ringwood, Victoria
    Quote Originally Posted by qsilverza View Post
    I bought the car in June, it has been back 4 times already, all for warranty claims in regards to electricals and all the standard electrical faults, all of which are documented all over the world.
    1st, it was the passenger side door lock wouldn't work
    2nd, passenger side window and power mirror
    3rd, the entire passenger door wouldn't work. Mirror, window, door lock, speakers..... the result was a new wiring loom for the whole door
    4th, driver's door window and door lock control panel grew a gremlin, which on 2 separate occasions opened windows on it's own, the passenger side one night when it was pouring rain!
    qsilverza, yes i entirely echo your sentiments, but i'm now in the situation that i NEED a car to get to and from work, as there is no public transport here and i can't afford to have my car going in and out of workshops every month..
    Feb 2008
    Auckland NZ
    strange i have had my GTI for over a year now, never had anything break or go wrong on it. A for doing an Alarm on a 2000 mk4 plus is kind of silly, i would have to point all the problems at the alarm or the actuall installer of the alarm that did not do the job correctly, seen them done here in NZ a few times, half the times just twist the wires together and then insulation tape around we go. Where the problems stop nobody knows unless reverted back to standard.
    The AVS alarms can happily co-exist with the factory VW immobilizers.
    Hope this points you to some place.
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Jul 2007
    Brissy
    Are there any other devices in the car which may be drawing a current ? Amp computer etc ?
    If there are then the doors will not double lock or immobilise and the light will stay on.
    Camden, Sydney
    I`d always suspect the aftermarket alarm first. I have seen too many old faulty units or ones installed by monkeys.
