Results 1 to 7 of 7
Thread: o2 sensor
    Apr 2013
    o2 sensor
    running the scan found this
    Address 01: Engine Labels: 06A-906-033-AVU.lbl
    Part No: 06A 906 033 AF
    Component: SIMOS33 1.6l 2V 00AT4083
    Coding: 00033
    Shop #: WSC 01271
    2 Faults Found:
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1116 - 35-00 - Open Circuit
    16706 - Engine Speed Sensor (G2
    P0322 - 35-10 - No Signal - Intermittent
    Readiness: 0010 1101
    am i able to take a o2 sensor from my dads bora mk4 v5 and place it in my golf mk4 1.6L? or do i need a to get a replacement? how bout a universal o2 sensor?
    i am quite a noob
    Jul 2007
    Brissy
    Other than the scan results, what problems do you have ?
    Have you reset the faults, do they come back?
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    just get a new one rather then trying to swap it over.
    from memory genuine ones arent too expensive?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2013
    I do prefer genuine, but it is quite expensive i think, vw quoted $300 for a sensor for a golf mkv. I was just curious to know if the sensors are compatible with all types of engines...
    Mar 2013
    Brisbane QLD
    as the fault is the heater circuit in the sensor then defo you will need a new sensor.. only get a gen vw one and dont try a used.. more than likely it will be stuffed... if the fault was NOT heater circuit but a mixture issue then you would be looking for air leaks etc first.... bang a sensor on it mate..VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jul 2007
    Brissy
    Sensor cost me $100 for NGK brand last year.
    MK4 GTI - Sold
    Apr 2013
    Quote Originally Posted by JustCruisn View Post
    Unfortunately they dont have any precat in stock gave vw dealers a ring and got quoted $270. know of any other companies that may have some?
