Results 1 to 10 of 10
Thread: Mk4 Clutch Woes - anyone around
    Dec 2014
    coopers plains, QLD
    morning
    Anyone around the Daisy hill area that might be able to help me out in exchange for a slab
    Daily is currently up on jackstands, driveshafts removed and im about to hopefully drop the gearbox and put in a new clutch
    Heard the next part is a bit of a pig if you are trying to do it solo?
    Mark
    Feb 2009
    Please Enter Location
    Piece of cake !
    Nov 2013
    Definitely not a piece of cake haha you might pull the box out on your own but you'll need help getting it back in for sure
    Jan 2011
    Gold Coast, QLD
    With help from someone how long do you think it would take to complete? 1hr?
    Can't make any promises but might be able to help out.
    Quote Originally Posted by Sirocco20348 View Post
    If you aren't messing about, an hour should be enough to get the box off, swap the clutch and put the box back on the engine. One person can refit everything.
    Dec 2014
    coopers plains, QLD
    An hour?!
    safe to say you could of probably changed a fleet of cars in the time it took me
    Most of it was a lack of half decent tools on my part. Tools that were too short for any decent leverage and me missing the 13mm bolt on the back near the drive-shaft didnt help. I couldn't get that off for love nor money and ended up jacking the wrench with a low profile trolley lift until it finally went. Alot can be said for a spline that properly clears the boots
    The box is now out however, im just going to let the hernia's settle for a few days then possibly hit someone up for getting the box back in (cheers for the offers)
    Im not going to beat myself up too much about it. The box is out and was done with my skull intact
    Jan 2014
    Narangba QLD
    so you got it sorted mate??
    Dec 2014
    coopers plains, QLD
    Potentially. Its all back in, i just have to hook up the shifter and starter and some other randoms. The bolts for the top of the case are a nightmare to get in. Set in really deep under a load of brittle 10 year old tubing
    In the end i invested in 20 bucks worth of ratchet straps and lifted it in. Was messing about for hours with jacks and all sorts. There is nothing more depressing that lifting it on, only to run out of energy and see it slowly slide off and hit you in the nuts
    With the straps and it took about 10 minutes. One strap to lift and the other i wrapped around the engine and case sideways and ratcheted them together
    EDIT
    To Top it off the lift for the bonnet failed and took out my mobile. Awesome day.....
    Attached Thumbnails Attached Thumbnails Mk4 Clutch Woes - anyone around-wp_20160527_21_20_04_pro-jpg
    Jan 2014
    Narangba QLD
    **** man no good
    If i had have seen this sooner i would have offered a hand. but alas.. you have the hard part all done. and now you know how to do it next time haha
    Dec 2014
    coopers plains, QLD
    Appreciated
    The next time this engine is coming out however its going into the mk1 and staying there
    At present im just getting the car running well before transplant day. Im sure thats a project thats going to make this clutch job look like a piece of piss!
