Funny your pics are upside down when viewed from here in UK .. Looks nice mate![]()
Hi,
Have not posted anything for ages, so thought I better had.
Doing a front end rebuild on the suspension. This started as changing the lower arms and discs, but I thought why not give her a birthday.
So new genuine vw discs and pads I bought over 7 years ago, all new fasteners and rubbers from VW, new brake lines, replacement brake pistons, all parts except calipers blasted and powder coated satin black. Calipers finished in satin heat resistant black.
New ball joints and a/r bar links, new wheel bearings.
Also replaced the M/cylinder as original had soft pedal pressure.
I cant work out why my pictures are upside down, have spent an hour trying to get right, so sorry to all but you will have to look at then upside down. Any help here would be appreciated.
If you need to know anything about corrados, then just ask me.
Hey mate, what are you doing in the UK, I thought you lived here? Yeah I know the pictures are arse about. Took them on my I Phone and even after editing them on the PC to be the right way up, they still came out upside down!! The front end is all reassembled now. I have the rear axle beam out and stripped. All parts have been powder coated, except the calipers. Just waiting for the final fasteners to arrive from Germany, then I can reassemble. Changed all nut and bolts for new VAG, new brake hoses, pads and axle beam rubber mounts. Should look sweet!
Ive not seen one of then since i worked for VW in the uk
DARKHORSE DEVELOPMENTS
BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. 0420839266
BRISBANE/GOLDCOAST/IPSWICH
www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
