Results 1 to 6 of 6
Thread: Where is the best place to get my Multivan Serviced in Melbourne??
    May 2022
    Coburg, Vic
    G'day All,
    I am looking for somewhere to get my T5.1 Multivan serviced.
    I don't want to go to a VW dealer but I need to find someone who knows Multivan's really well.
    I have a rough idle issue at just over 70,000kms and I need a pro to diagnose.
    Any recommendations would be great.
    Cheers.
    Dec 2006
    Kilsyth, VIC
    Highly recommend these guys:
    Volkwerke
    Which reminds me, I should book a service for my Golf
    VolksTech in Hiedelberg West so not far from you (assuming you are in Coburg as per your forum info).
    If you have a rough idle then you may well have some carbon buildup in your intake (i know this is common with other modern diesel engines with EGR systems - my Audi SQ5 had the same thing a few years ago and removing the intake manifold parts and cleaning about 6mm thick gooey carbon off everything made it nice and smooth again).
    Some other suggestions in this thread: Best VW mechanic in Melbourne
    2017 Ford Fiesta ST
    May 2022
    Coburg, Vic
    Thanks Lucas, i didn't think of that, will definitely check the intake, I have only had it for 6 months and it's got low for it's age, and I get a feeling previous guy only did short trips.
    Quote Originally Posted by Multivan04 View Post
    Short trips and low load driving (ie idling or coasting at low rpm/load) is the worst case for building up carbon on the intake. So if thats the kind of life its had up until you bought it, then its likely to be the issue causing the rough idle.
    2017 Ford Fiesta ST
    Feb 2008
    Adelaide,Oz
    The goop mainly builds up around the EGR.Wouldn't bother with further down.Did mine around 130K. It didn't have a rough idle though.
    How to remove Intake Manifold 2.5 174 AXE - The Brick-yard
    Steve
    04 T5 auto 2.5L TDI
