Results 1 to 10 of 10
Thread: Transporter Towball for Tandem
    Jun 2011
    Im looking at getting a tandem trailer for work, any idea of what I might be up for for the supply and fitting of such a rig?
    It’s for wood heater deliveries, a single axle may be ok but tandem appealed because we sometimes move 400kg+ appliances.
    Currently been using a Ute with Tail lift but it’s leaving with an ex employee.
    Pacific Paradise QLD
    Quote Originally Posted by Foxpuppet View Post
    A TOWBALL is about $9 Its the TOWBAR its attached to thats where the money is and possibly a grand plus electrics if needed
    Jun 2006
    with the dust and flies in western Victoria
    The bar is around $800 then there's another couple of hundred for the electronics and then there's the fitting. I was quoted around $1300 all up.
    As for a trailer... don't forget ramps and an electric hoist!
    Jun 2011
    Quote Originally Posted by Seano View Post
    We have specialist gear for loading and unloading it just getting it to site.
    Any recommendations on good places to go? Saw a few mobile ones for just under $1000 that come to you.
    Jun 2011
    Yes, I should probably go back and edit the title.
    Jan 2008
    Mallacoota, Vic.
    Check the ball mounting height if you're planning to use a tandem. On a van, it's usually pretty low because otherwise it fouls the door. You then need to check your tandems hitch height, as they are often too high for the low mounted ball, meaning it may have to be forced down onto the ball (this doesn't happen with a single axle trailer). Insufficient or negative down force on the hitch is very dangerous, as I found one time with a big hired tandem of furniture, moving house. After 500Km the tow ball bolt was only hanging on by a couple of threads. I reckon it would have lasted about another 20Km. If you're getting a new tandem, make sure it's hitch height is made to suit the van set-up.
    Quote Originally Posted by 4wheels View Post
    If you load trailer correctly you wont have no ball weight and even a tandem usually has its wheels set back a bit to give some ball weight.
    If with furniture you loaded all the heavy stuff on the back you would get it loaded off and cause that But that isnt the trailers fault and you could have loaded to prevent that.
    If with a new trailer the hitch is too high its a reasonably easy fix to get it mounted UNDER the A frame chassis and so lift the trailer flatter
    Doesnt fix user error with poor load distribution though
    Jun 2006
    Honestly...anyone that does Hayman Reese. I don't think there's much else left in the market and the last one I saw for a van wasn't that fabulous.
    I'm still hunting one for the dual cab but it's either HR or a European made gooseneck thing these days...
    Mt Cotton
    Loading is critical otherwise its a case of the tail wagging the dog , seen a few examples of incorrect loading with the tow car down an embankment with the trailer wrapped around the car !!
    Yes but some blame the gear when they have no idea of how to do it. I had a trailer that empty had about 10lb ballweight but with a front heavy load it could be enormous.. Had a big car transporter with no brakes connected and loaded with a couple of tonne of rocks nearly push me over a bank on a corner. Was my fault going too fast LOL
