Results 1 to 3 of 3
Thread: VW T4 tyre pressure question
    Mar 2020
    Hobart, Tasmania
    Hello all,
    A little confused, I hope someone in the forum could give me some advice.
    I've been enjoying a pre-loved 2001 VW T4 Diesel Trakka for around 16 months now. I have a minor physical disability and the camper has been a great way to access nature even if I cannot now go bushwalking.
    The previous owner had fitted 16" (Audi) alloy rims and low-quality car tyres. I have kept the rims but fitted Duravis R411 215/60R16 C 103/101R tyres.
    The placard says:
    "195/70 R15 C 104/102R on 6x15 Rim
    Pressure: Front=380kPa (55psi), Rear=400kPa (58psi)
    or
    205/65 R15 C 100T on 6 or 7x15 Wheel Rim
    Pressure: Front=350kPa (51psi), Rear=320kPa (46psi)"
    Since the placard doesn't mention that tyre width let alone 16" rims I'm at a loss as to the correct pressure I should be using front / rear. Are you able to advise me please?
    Kind regards
    David
    Jun 2006
    with the dust and flies in western Victoria
    I tend to run mine with 50 in the front and 45 in the back... And I run 205/70R15C tyres. I could run less in the back given it is a mostly unladen DOKA. However, given yours is a laden camper....
    Aug 2016
    NSW
    Quote Originally Posted by Seano View Post
    Yeah, with C rated tyres, 45 - 50 would be the go.
    If you look at the fine print on the tyre, it will tell you the maximum psi.
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
