Yep as above, just flush out what you can and it will be fine. A bit of petrol left in the bottom of the tank with a whole tank of diesel will do nothing at all given the dilution factor, probably clean out the injector nozzles nicely! You already have a 50/50 mix, so the dilution is going to be even greater than if it was a whole tank of petrol ( as usually happens ).
For the record my brother topped his mechanic apprenticeship back in the day, and is quite the mechanical guru, and he's done this, so don't feel so bad.
2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside cams | Darkside dump pDPF | Wagner Comp IC | Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Michelin 4s | Golf R subframe | Superpro sway and bushings | 034 engine mounts | MK6 GTI brakes.
