We have a model that you described I have one in my work T5 .
Attachment 31374
Attachment 31375
Printable View
Attachment 31374
Attachment 31375
Hi there Sunny,
Just wondering what speakers you installed in the roof? I pulled the ceiling out today, there's not much depth there... Did you use a spacer or something?
Lovely fitout mate
Mitch
Hi Mitch the speakers are a two way but I made sure they were pretty shallow in the magnet area , if you place them towards the outer edges you will find the roof trim curves downwards slightly but as the roof curves on the outside there is more depth so they fit quite well .
Yep ok, cheers. The speakers I want are only 50mm deep overall, so it should go close, if not a spacer will be ok.
I've read about the sound proofing you use and why. I have some of this left over, the worry is that it might guy absorb moisture? Have you, or anyone else used this before? I was going to do the roof with it...
Dunlop 8m Carpet Underlay | Bunnings Warehouse
Mitch
That stuff will be fine you would have to submerge the van to cause any issue with moisture , our vans for the last 30 odd years have always had the stuff I use and never any issues .
Hi Sunny,
That is seriously awesome work.
I'm about to order a T6.1 4Motion Transporter and will look to put in a good amount of sound deadening and then trim up the inside but i know i'll not get anywhere near that quality. I'll either moderate my expectations or save for a pro to do it.
I had a look at the old link for the product you mentioned but it must have changed. Is this is the product? Underlay 900 GSM | The Nolan Group
Cheers Carl
Yes thats the stuff I used , Nolans in Yatala have changed their selling method , you might have to get local motor trimmer to order it for you as they may not sell it direct to the public anymore .
