Results 1 to 10 of 14
Thread: LPG for T4?
    LPG for T4?
    Hi all
    Have just picked up a 1999 petrol 2.5 T4 Synchro, would have preferred a TDi but this one has everything else I want.
    Although the price of ULP is dropping I'd still like to convert it to LPG. Questions:
    1. Does anyone out there know how these motors go on LPG? Any power loss? Any mechanical issues?
    2. Can anyone recommend an installer, preferably in Melbourne? All the ones I speak to here (Albury-Wodonga) don't seem to have any experience with Transporters.
    3. I've heard of one options which goes underneath but it requires 3 x 20 litre tanks and all the local installers just say "No way." Anyone have any experience of this or know of an installer?
    Thanks
    Phil
    Camden, Sydney
    I have seen a couple of conversions to LPG and they are all pretty basic. They just disconect the injectors and use the throttle body like a flap or a carby.
    I used to have a T4 2.5L LPG Ute and it went hard. Made a great noise with the pod filter too.
    Jun 2006
    with the dust and flies in western Victoria
    phil
    The syncro option makes the underfloor tanks a bit more problematic. The rear diff takes up the spot for the spare wheel which is typically the spot for the gas tank...
    A manifold style tank might be what you are after
    So try having a yarn to these guys www.apamfg.com.au
    Mar 2008
    Give Volkspower in Melbourne a call (03) 9808 6777. Speak to Dean the owner or Brett.
    I have heard from a number of people that LPG running on the 5 cylinder petrol engines is not ideal. But I really have nothing to validate this view.
    Best Regards,
    Scott
    Thanks guys
    Thanks for that info guys, I'll get in contact with these places and see what they say then try and summarise it on here.
    Phil
    Sep 2008
    Gold Coast
    I drove a 1998 T4 2.5 on LPG while shopping around for my van. The vehicle was single owner and had been on gas from just after its first year (substantiated by the upcoming expiry of the 10 year certification on the tank). That the engine was a little clattery might have been more a reflection of haphazard servicing and 240K mileage than anything else but it didn't seem to be lacking in power at all (certainly better than the gutless 2.0L petrol I'd driven an hour earlier).
    The Synchro aspect makes for difficulties on the underfloor fitting though as others have adequately pointed out - no spare wheel area to put a doughnut tank in. I realise putting the tank in the inside load area has its disadvantages but at least it doesn't have to look too fugly if you position it right then box and carpet it. You could also consider asking about having a smaller tank fitted inside than the huge ones you often see, that way it might be less of an intrusion on space.
    My own experience was the reverse of yours, Phil - I went looking for a petrol T4 already on LPG or one cheap enough to convert on my overall budget and came away with a diesel cos, as you put it, it had everything else I wanted.
    Getting closer to a solution
    Thanks for that info Deeceer. Good to hear that the 2.5 motor goes well on gas.
    The underfloor tanks for these vans aren't the donut ones or the normal cylindrical tanks, they're like the manifold one from APAMFG pictured in an earlier post above. They just sit under the middle of the floor of a 2WD van, as a result they're no good for a Synchro. They're also only 60l I think.
    Following the other leads, I've spoken with Volkspower, they had a Transporter on gas for 300 000km with no problems. He said that he made sure that he always started it and stopped it on petrol rather than gas. He also said that the main issue with LPG conversions wasn't the fact that it was running on LPG but how good the conversion was. He said to go straight to Progas in Huntingdale. I gave them a call, no worries they've done Transporters before, they can't do the underfloor (APA manifold style) tanks any more because they can't get some sort of fitting any more so it has to be inside. Only a 1 week waiting time (compared with months here in Albury Wodonga) and about $700 cheaper than any other quote I've got locally. So I'll book it in and have a holiday in Melbourne with the $$ I've saved.
    After the hassle of speaking with workshops here and them not knowing how the conversion would go, or how long it would take or even how much it would cost it was great to speak with someone who had experience.
    This is a great forum in tha regard.
    Phil
    Mar 2008
    Phil,
    I am glad Volkspower pointed you in the right direction - and you are able to same time and quid or two.
    Regards,
    Scott
    Jan 2009
    Weingarten, Germany
    Hello from Germany.
    I am a little bit curious. My T4 VR6 is running with LPG since march '03 here in germany and the use of LPG got more and more popular over the last 6 years.
    From 550 LPG stations up to over 4000 - for the "small" germany of course.
    How much is the benefit from using LPG in Australia compared with diesel and gasoline?
    Greetings, Martin
    PS: A tiny picture of my ride (the green one):
    Aug 2008
    Hi Martin, hows winter treating you, I hear its been very cold in Berlin recently.
    LPG is very common over here as well with more and more conversions taking place due to a government funded rebate on the installation cost.
    Rough prices at the pump here right now in AUD and Euro are:
    LPG $.65cents/l =.33Euro
    Petrol $1.12/l =.56 Euro
    Diesel $1.25/l= .62 Euro
    Factor in a 25% increase in consumption of LPG over Petrol its still a good saving on LPG.
    2014 T5.1 Multivan Tuned by Pendle Performance Australia
