I'm just guessing, but the T5 I recently bought at 277kms had its EGR valve 3/4 blocked with oil and blowby, yet everything else was pretty clear. It sure seems to be a crud collection point. Do you clean yours with spray in the least? I'd suggest unbolting it and cleaning it out, depends on the year and exact engine model, but the flap and EGR valve are the two things to play up and put the car into limp, and I feel this will be because the DPF is full and it wants to do a regen but without the EGR and flap working it can't. Could be many things, but this seems the most likely possibility to me with limited diagnosis of your actual car.
2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside cams | Darkside dump pDPF | Wagner Comp IC | Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Michelin 4s | Golf R subframe | Superpro sway and bushings | 034 engine mounts | MK6 GTI brakes.
