Results 1 to 7 of 7
Thread: Loud noise after shutting the engine off
    Feb 2019
    Hi guys - does anybody have any experience with a loud high pitched whirring noise after turning the engine off in a ‘96 VW 2.5L petrol transporter?
    Keeps going for quite a while and it’s pretty loud - (intermittent issue though - doesn’t happen every time...)
    Mt Cotton
    Would you describe the noise as like a cow mooing gently ? if so its the same as ours no big deal other than mooing when you switch of from time to time , you can see they do call them a moo valve on Ebay But as yours is a 97 this may not be the problem . OEM Turbo Solenoid N75 Moo Valve VW T5 Transporter 1.9, 2.0 & 2.5 TDI 1K0906627A 4058633260939 | eBay
    Aug 2012
    Qld
    Maybe worn bearings on one of the radiator fans? My 2.0L 96 transporter has two radiator fans and sometimes when the weather is warm one of them (think it's only one) will kick in for a minute or two, when the ignition is turned off, if needed.
    Aug 2016
    NSW
    Either the radiator fans or the auxiliary water pump is my guess.
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
    May 2006
    Adelaide South Australia
    I was thinking water pump myself. Take a look at the fan & watch to see if the noise stops when the blades stop turning. You would need to touch the auxiliary pump to see if it is running, careful it will be hot.
    Numerous Mk1 Golf diesels
    Apr 2019
    Deep South
    My 128kw 2.5 TDI is doing the same. Pretty sure the actual mooing sound is the vacuum pump. Still in the process of working out why, thinking the N75 valve could be the culprit.
    Aug 2016
    NSW
    The 'moo valve' only last for about 2 seconds.
    (mine's been doing it for ages and although I have a new valve........I still haven't got around to changing it)
    The fans or aux water pump can go a couple of minutes.
    2018 Crafter Runner
    2024 Crafter Auto
