Results 1 to 8 of 8
Thread: MY11 Multivan Bluetooth - can it be fitted later?
    Yep, should have ordered it....didn't...... now i want it.....can it be done?
    2011 multi van comfortline in night blue metallic, 2011 Jeep Grand Cherokee CRD in Mineral Grey
    Jan 2007
    Probably only by changing the head end unit.
    I fitted a Kenwood with sat nav and blue tooth - an expensive way to go, but it works great with my Blackberry.
    Golf V TDI 2005 - SOLD
    Volvo C30 D5 - I've got a hat as well!
    Multivan Highline T5 TDI 4Motion 2005
    Hond Civic VTI 2001
    Adelaide hills, SA
    Quote Originally Posted by Philbie View Post
    I don't see the reason why it shouldn't. You can also fit RNS510 radio in a new T5, if you didn't optioned it. See Sharkie's sticky http://www.vwwatercooled.org.au/f136...ery-54477.html , he fitted RNS510 in his new T5.
    Nov 2007
    Transporter recently fitted the latest Bluetooth to a new Skoda, so I believe it can be done. Have a look at his thread in the Skoda section for details of where its from.
    Be less than $500 landed + fitting and coding. I'd certainly be doing it if I were you. Also, if it turns out not to work with the Multivan, theres plenty of Golf/Tiguan drivers who will take it off you for no loss to you .....
    Adelaide hills, SA
    Here is the one I bought the parking distance sensors from and still waiting for them (bought on 19/02/11), but I'm confident that they will arrive.
    BlueTooth
    Bluetooth unit 5N0 035 730 D 5N0035730D RNS VW,Skoda - eBay (item 330525181241 end time Mar-31-11 08:36:46 PDT)
    Jan 2012
    Sawtell
    Sorry to bump an old thread but better here I guess...
    I have installed a 9w7 kit from bluewagen which works fine with the RNS510... In a few guides they suggest mounting the unit behind the climate control module under the head unit. Sad to say I couldn't make it fit there. I ended up with the control module wedged into the hole under the drivers feet where the clutch would have been. Snug fit, but we will see how it goes. I couldn't be stuffed trying to run the cables under the floor - lazy I know.
    The only annoying thing is the microphone that came with the kit does not fit anywhere inside the roof console. There is one section which I think is made for a microphone but the one I have doesn't fit.
    This is the console I have:
    The microphone i have is rectangular and the section where I think it should go is basically rounded and on the passenger side. Sorry no photo - I will pull it apart again later.
    Does anyone have any idea s? I'm giving my kids about 2 weeks before they pull on the mic the way it is and break it
    I had the dealer I purchased my van from install the bluetooth kit and RNS510 I bought from eBay. They drilled a series of small holes in the roof console and used sikaflex to glue the mic in place. Works a treat and neat install. My wife tells me she has never noticed the holes and thought thats how they came.
    2012 Caddy Maxi Life
    2011 Multivan
    2008 Skoda Scout (Gone.......L)
    Sydney NSW
    I had my bluetooth factory Installed, I believe it is all under the passanger seat.
    2011 T5 4MOTION Duel Cab Optioned up.
