Had a similar problem with my B6 Passat, all worked fine with normal globes but once I put LED lights on the trailer, nothing. Do you have LED lights on the bus? Plugged the trailer onto a Toyota and worked fine, normal lights, not LED's. I had to buy a special connection, that plugged between the car plug and the trailer, from VW's to allow it to work. Over $100 from memory.
