Results 1 to 9 of 9
Thread: Rescue my T5 cupholder
    Aug 2017
    Holsworthy, NSW
    Rescue my T5 cupholder-cupholder-jpg
    It didn't take long before my better half broke one side of the cupholder - see photo attached. Any chance at rescue? Any tips for me before I try and force that metal shaft back into place and break it properly in the process?
    Thanks! Sam
    Aug 2016
    NSW
    All I know is that they are bloody expensive to replace!
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
    Mt Cotton
    Mine broke at the hinge point about 8 years ago so I made up a thin piece of alloy and used acouple of small screws to hold it in place , still working 8 years on !! I'll take a photo later and repost .
    Jun 2007
    Melb.
    Avoid replacing at all costs because as mentioned it's expensive and time consuming. I replaced mine and found an overseas VW website with detailed instructions on removing and replacing. From memory it involved trim removal starting from the passenger footwell and airbag trim cover on passenger side as well and took a while and many unrepeatable words.
    I'll try and find the OS VW forum link unless someone beats me to it.
    Aug 2017
    Holsworthy, NSW
    Hey thanks all, links and photos would be greatly appreciated for when i build up the courage then fail at levering that metal shaft back into place
    Jun 2007
    Melb.
    Quote Originally Posted by heyasam View Post
    Removal of Drinks Holder with Pics - VW T4 Forum - VW T5 Forum
    Jun 2007
    Melb.
    I should add the drink holder unit I bought from my dealer had the positive and earth wires in reverse to the unit originally in my van, so just check carefully as at first I thought the replacement unit was faulty and my cig. lighter and back-lighting didn't initially work.
    I'd also suggest to carefully note how the wiring is routed in the underside of the tray, as it needs to be seated exactly as it was before removing to avoid fouling when you slide the tray shut...so I had a few dramas when replacing.
    Aug 2016
    NSW
    That's a good tute!
    2018 Crafter Runner
    2024 Crafter Auto
    Dec 2006
    Kilsyth, VIC
    That a lot of steps to get to that parts, but it's all pretty straight forward unscrewing and removings bit so you should be fine if it comes to that.
