Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: T5 2.0 L biturbo FWD 132 KW Multivan overheating
    Aug 2019
    Southport Qld
    Have an overheating issue on this van. Anyone have any experience with diagnosing overheating. We suspect partially blocked radiator . Inspected water pump-ok. Thermostat -ok. Drive it for 15 mins , it gets to 90oC is stable for a little while. Then it starts climbing to 130 , then if you reduce speed it comes back down to 90. Eventually it loses coolant via expansion chamber and check coolant light comes on. Check rad. cores with Temp probe ? Next step is to pull radiator out and inspect cores.No previous service history. No sign of leaking head gasket.
    Apr 2014
    Chelmer, Queensland
    I had a similar issue & it turned out that there was a split in the bottom tank of the radiator that only opened up when warm, though I wouldn't think that was the only possibility.
    Aug 2019
    Southport Qld
    The mechanics are looking at it again on Monday. I see there is a kit to test for CO in the radiator fluid. This may tell us head gasket or not.
    Mt Cotton
    You should be thankfull VW put a temp gauge in your model because ours does not have one at all , my 2005 has one but not our 2011 model .
    Aug 2016
    NSW
    Yeah.............that was the big disappointment when I got my 212 model..............no gauge.
    You always drive frightened..............until the warning light comes on............and then you're REALLY frightened!
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
    Adelaide hills, SA
    Quote Originally Posted by Sendo_VW_multivan_2010 View Post
    How did you inspect the water pump? Did you remove the pump and check the impeller?
    Is the radiator fan working? Are the radiator fins clean, not blocked with mud or grasshoppers?
    Aug 2019
    Southport Qld
    Mechanic pulled apart pump and thermostat , said they were both ok. No bugs in radiator/ intercooler. Will let you know what they find this week.
    Aug 2019
    Southport Qld
    Fans working , they ramp up and down depending on temperature.
    Aug 2013
    Esperance
    Hi Sendo, can’t help you with overheating issue sorry,but, are you aware of the oil consumption issue with some bitdi engines ? Regarding oil temp mine gets to 130 if I push it hard, normally runs at about 102-112, many owners on oil fb page have posted about adding a small oil cooler, cheers
    Aug 2019
    Southport Qld
    Quote Originally Posted by Kombi View Post
    Hi Kombi
    Thx for the info. Do you have a link to that FB page?
