Results 21 to 30 of 33
Thread: EGR blanking options?
  1. #21
    If an experienced VAG diesel tuner is saying don't do it - I wouldn't do it.
    2017 Ford Fiesta ST
  2. #22
    Dec 2015
    sydney
    Following up this thread i can confirm no issues after 3k+ kms of mixed hwy and town since installing the emulator
  3. #23
    Adelaide hills, SA
    Quote Originally Posted by twistit View Post
    It’s too soon, 3,000km is not long enough distance. Keep an eye on the DPF health for at least 20,000km
  4. #24
    Jun 2011
    Quote Originally Posted by Kombi View Post
    t’s been a while since I researched this problem, plenty of information if you join the fb group.
    From memory the aluminium particles contaminates the engine oil in the cooler part.
    The combination egr & cooler & filter was replaced as a complete unit in my case.
    I was told blocking egr without removing dpf will cause problems, I tried it anyway, after about 5000km mine went into unregenerable limp mode with blocked dpf, my understanding is that you need the egr to get the high temperature needed to burn the soot in dpf.
    Hi Kombi, What’s the FB group called?
  5. #25
    Dec 2015
    sydney
    It’s now on 20,000kms since the emulator and no issues still fyi
  6. #26
    Aug 2013
    Esperance
    Quote Originally Posted by Foxpuppet View Post
    The cooler that corrodes is the exhaust gas to water not the oil to water. There are two coolers in the unit and as the fins in the gas/water cooler breakdown due to the hot gas the aluminium particles are drawn into the combustion scoring the cylinder walls. You then burn more oil and it also gets contaminants into the sump. That’s why if you prevent the gas recirculating back into the combustion by blanking the EGR valve you prevent the problem. Some also join the inlet and outlet of the coolant passing through the gas/water cooler as it’s now not required. Just thought I would post this as the thread was not clear on how the alloy gets into the cylinders. Of course as stated all this also needs a software mod and opening up/removing the DPF filter which would eventually clog up due to no regens taking place.
  8. #28
    Feb 2024
    Merimbula
    Hi twistit
    Just wondering if you has success with the egr emulator and where you may have purchased from.
    Regards
  9. #29
    Mt Cotton
    Pendle Performance UK is a specialist company doing this , a few years back there was a local agent but after Covid he went quiet . Try the Australian Agent for Pendle Performance Australia his details are on this forum along with his Facebook page PendlePerformance HQ Australia | PendleHQ - Australia ?? Marcus Taylor who is our Australia HQ outlet is going to expand the dealer network across ?? | By Pendle Performance Ltd
  10. #30
    Pretty sure the Aust dealer for Pendle is no longer around. I tried to find them yesterday to recommend to forum user AEA.
    2017 Ford Fiesta ST
