T4 2.4 diesel injector pump
Hi all desperate here , I cannot start engine 1996 - 7 2.4 and I suspect that the fuel cutoff solenoid on the end of the injector pump has died have 12v on one wire and 10.4v both positive . I am assuming thats correct with key on , had some problems a few months ago when the engine would keep running after the ignition was switched off and had to stall to stop or quickly turn key off and on a few times always random on how it would stop . next problem is should the solenoid make a noise when turned on and how does it come out have two recesses in plastic body at end of pump but cannot make any tool fit to undo. Help please Howard
- You may not post replies
- You may not edit your posts
Forum Rules
