Results 1 to 6 of 6
Thread: T6 Oil Filter Access/Location
    May 2013
    Not far from Cooma
    Hi folks,
    As per the thread title where is the oil filter in a T6 and what's the access like for competent home mechanicals types?
    Last night the check oil level warning started so I want to do an oil and filter change today.
    Also would you recommend using a flush product with the old oil?
    Cheers,
    Tony
    Skip to about the 5.00 minute mark. Its a cannister filter and you access it from underneath the car near the sump.
    May 2013
    Not far from Cooma
    Thank you muchly, but mine is as per this video and accessed from above.
    Quote Originally Posted by TonyMax View Post
    Funny as I linked to that video first and then realised it was a T5 and might be different to a T6.
    May 2013
    Not far from Cooma
    Mine is October 2016, T6 but no AdBlue. Maybe some of the mechanicals are T5?
    Could be possibly. The videos linked above are Uk/European spec cars so they might also be a bit different. Your might be right on the edge of when they were switching from T5 to T6 and its a bit of a mix?
    No AdBlue - count yourself lucky. The AdBlue systems are notoriously problematic and very expensive to fix so that's one less thing to worry about.
