I had a similar issue & it turned out that there was a split in the bottom tank of the radiator that only opened up when warm, though I wouldn't think that was the only possibility.
Have an overheating issue on this van. Anyone have any experience with diagnosing overheating. We suspect partially blocked radiator . Inspected water pump-ok. Thermostat -ok. Drive it for 15 mins , it gets to 90oC is stable for a little while. Then it starts climbing to 130 , then if you reduce speed it comes back down to 90. Eventually it loses coolant via expansion chamber and check coolant light comes on. Check rad. cores with Temp probe ? Next step is to pull radiator out and inspect cores.No previous service history. No sign of leaking head gasket.
The mechanics are looking at it again on Monday. I see there is a kit to test for CO in the radiator fluid. This may tell us head gasket or not.
You should be thankfull VW put a temp gauge in your model because ours does not have one at all , my 2005 has one but not our 2011 model .
2018 Crafter Runner
2012 T5.1 6sp manual.
2024 Crafter Auto
Hi Sendo, can’t help you with overheating issue sorry,but, are you aware of the oil consumption issue with some bitdi engines ? Regarding oil temp mine gets to 130 if I push it hard, normally runs at about 102-112, many owners on oil fb page have posted about adding a small oil cooler, cheers
