Hi All.. Am interested in fitting a multi function wheel to my Edition 30
I am sure its not too hard but any tips from someone who has done it would be appreciated
Fittting
Do you need to change steering wheel control unit?
Programming ..etc
Thanks
It can be done quite easily but it depends on what new wheel you want to use and what your current wheel is.
The control unit may need changing. Again depends on what you already have.
Coding if required can be done readily with a VCDS cable.
Sent from my Nexus 9 using Tapatalk
Using Tapatalk
