Did you try the button while you have the ignition on/motor running and you are in reverse gear?
I've just picked up a 2014 Ultimate. It has LED lights on the roll bar to light up the rear, the button is on the dash next to the Parking button, but can't see the lights come on. Does the car need to be stopped/off, ignition on/off?
Hi Zed, you will need to test it yourself.
