Results 1 to 10 of 10
Thread: Reverse sensors
    Jul 2011
    Reverse sensors
    if i have the dealer install reverse sensors prior to delievry does this mean they will be aftermarket and not be intergrated witht the RCD-510 unit in my highline? i dont think i'd want some tacky add on, if its from the dealer id like it to be intergrated. the dealer cant answer my question....any advice?
    Jul 2011
    my assumption would be the factory fitted units would be intergrated???
    May 2011
    paynesville,vic
    Quote Originally Posted by dutchyvan View Post
    this is correct the dealer installed reverse sensors will be intergrated
    Jul 2011
    I was thinking of the factory installed and dealer installed units as two different things. So if I buy a vehicle that dealer has on the lot and they install sensors at the dealership, will it be integrated ?
    Melbourne, VIC
    Correct. When I optioned mine I was advised that the 'factory fitted' RPS would be fully intergrated and the physical appearence of the sensors fit would be neater. It meant a long wait for the vehicle but I liked the idea of factory fit, not sub-contractor fit.
    Pascoe Vale, Vic
    Any Sub-Contractor (i.e 'dealer-fit accessory') will NOT integrate with the RNS/RCD510. Only the factory fitted sensors will. At this stage there is no genuine accessory available for the Amarok.
    Daily Car: Random BMWs | My Toy: R33 Skyline GT-R | GF's Car: 1954 Beetle 'Oval' | Our (Her) Car: Alfa Romeo MiTo Sport
    Nov 2007
    Quote Originally Posted by flyingfridge View Post
    Given that there are other models' (Golf Tiguan etc) OEM parking sensor kits available that do integrate fully with those cars' RCD/RNS systems, and the fact that we know that in some cases even VWA is unaware of other integration possibilities (Multivan RNS510 non-factory fit for instance & Tiguan DSG paddles MF steering wheels), do you think it would be a possibility in this case?
    I for 1 would give it go .... source a Golf/Tiguan OPS system, install and hook it up and see how it goes ..... odds are you'll have a good outcome.
    Unless Sam or some other dealer has hands-on proof that it will not work?
    Adelaide hills, SA
    Exactly right Sharkie, I thing that there is a good chance that it will work.
    Jul 2011
    Swanny
    reverse camera
    We just collected our Rok from having the radio swapped over to the RNS510 unit and at the same time having a reverse camera fitted. The 2 integrate perfectly. The camera sits above the tow ball, giving a great view of the tow ball and all around. Very happy with the results. Not yet convinced about the RNS510 as a media unit yet, a few glitches with speakers not working etc. The cable for the MDI has been connected through the cubby as requested, and not in the glove compartment, and is a neat fit.
    Pascoe Vale, Vic
    I guess there's nothing to say a Golf or Tiguan kit wouldn't work. You'd have to ask for it very specifically in your agreement with a dealer though - there wouldn't be many out there willing to risk putting holes in your rear bar on a 'suck it and see' approach....
