Results 1 to 10 of 15
Thread: Any tips for buying used Amarok?
    Jan 2020
    Hi all, I'm new here and currently in market for late model Amarok & would appreciate some tips on what to look out for.
    Also, any comments on these 2 I've found?
    Option 1: 2016 (MY17) 4x4 Core - located at VW used car dealer, low kms, car previously owned by "VW Australia Fleet" - what does this mean?
    Option 2: 2018 (MY19) 4x4 Core - private sale, very low kms, only issue was DPF warning light came on - took to dealer who revved/warmed engine to clean it out - is this common for low use? and would I anticipate further issues with DPF with this issue happening so soon?
    cheers,
    Jim
    Feb 2019
    Gold Coast, QLD
    V6? 2Lt? manual or auto??
    Brisbane, Qld
    Run a mile if the DPF light came on.
    Regarding the DPF light on the 2nd option - this is common on cars that do mainly city driving as the DPF often does not get the opportunity to clean itself properly before the engine is turned off. We have had a few issues with the DPF on our car in the 18 months or so that we have owned it - a bit of a pain in the butt if im honest but something VW/Audi could fix by having a warning come up on the dash when the DPF is doing a clean (like Toyota and several other brands do).
    Nov 2007
    If you want to use it for some more adventurous off-roading, get the manual.
    In the Core 2.0TDI it has a proper low range function on the manual. Also, as of end Jan 2020, the V6 Core is now also available with the low range manual gearbox. $50K for the V6, less than $38K for a new Core 2.0TDI.
    None of the auto's have any form of low range.
    Jan 2020
    Thanks, yeah a warning light that tells you to keep driving while its cleaning itself sounds smart, rather than a light that tells you something is already wrong.
    So when the Amarok DPF light comes on, does that mean a good run down the freeway will fix it; or does it require a visit to the dealer to repair/fix and clear codes?
    trying to gauge how inconvenient and costly this could potentially be.
    Jan 2020
    looking at 4cyl 2Ltr auto...
    more of a recreational vehicle (not serious off-road); and wont be towing..
    so i reckon the auto 4motion will suit our needs
    Quote Originally Posted by iamaRok View Post
    I've had both scenarios with mine. Basically (in my experience) when the light comes on your dash its time for a drive to let the DPF self clean (takes a good 15-20mins to clean once it starts, but you never know when it starts!!!) but its a fine line between a highway drive and a visit to the mechanic. I have had 2x trips to the mechanic to have the DPF burned off using software because the car simply refused to self clean.
    Personally i will never buy another modern diesel again - I have had quite a bit of inconvenience and frustration with DPF issues on mine in the past 18 months. Although i shouldn't have to in a 4 yr old car (only done 45,000km mind you), i now use an app on Android called VAGDPF and a Carista OBD dongle to check the DPF every few days to see how full it is.
    Now that the VAGDPF app tells me when the car is doing a DPF clean, I will go for a drive until it is finished (pretty annoying when you are 2 mins away from home when it starts though as is quite often the case) rather than turning the car off mid-clean.
    Thankfully my costs have been low, but it's certainly an inconvenience having a new car that's having issues. And every time it happens you lose more trust in it.
    Feb 2019
    Gold Coast, QLD
    2018 v6 auto from new. 45000km here.
    Never had an issue with dpf, however I drive 50km to work each day each way on the freeway.
    I haven’t altered my driving to suit the DPF, but I notice the burn as the revs pickup at idle from 800ish to 950ish. But if I get home and it’s doing a burn I just turn it off... zero f’s given.
    But if the dpf light has been on before, I’d run a mile or get someone with obd2 reader and vagdpf to check the status of the dpf.
    Early model 2 litres had an issue with the timing belt cover, the serpentine belt would fail and get under the cover and throw off the timing belt... resulting in f’d engine. This was rectified in later models.
    The early model 2L also have a problem with the AC pulley. You can get an upgraded pulley to replace it if it fails.
    That’s about all I can think of at the moment.
    Quote Originally Posted by doinitsideways View Post
    50km on the freeway each way to/from work is perfect for a DPF burn off so its unlikely you will run into problems with that kind of driving.
    My wife's work is about 25-30km away which isn't long enough for the engine to get up to temp and then trigger the burn off and then to allow the burn off time to finish which is why we have issues with ours. I have heard many people say they notice the idle RPM's are higher when doing a burn but my car (also V6 TDI but in the Audi SQ5) is no different to normal. Before i had the VAGDPF app, the only way i knew we interrupted a DPF burn was that the fans would be running like crazy when you turned the engine off (but you cant hear them with the engine running).
    My car does a DPF burn off much more regularly than I was expecting (based off reading peoples experiences with other TDI cars). When stock it was approx every 500-600km, but now that it's got a stage 1 tune it's producing more power = more soot so it's filling up more quickly, so it's now approx every 400-500km.
