Results 1 to 5 of 5
Thread: 2012 amarok ABS/ESP issues
    Oct 2015
    Brisbane QLD
    Hi all,
    Anyone encountered the issue on a 2012 amarok 4X4 manual.
    ABS/traction light stays on.
    I’ve attached a photo of the codes that are not going away.
    -I have reseated the electrical plug on the ABS module. No success with DTC erasure.
    -have not checked each wheel speed sensor yet.
    -have not checked ABS/traction system fuses yet.
    It is saying electrical fault within ABS hydraulic unit2012 amarok ABS/ESP issues
    I’m thinking internal electrical failure of a system or sensor within the ABS module.
    Hoping to avoid the $650 replacement of the unit and coding. 2012 amarok ABS/ESP issues
    Get one from a wrecker. Make sure you take a copy of your current ABS long coding string as the VIN is encoded into it as well as a bunch of settings.
    Oct 2015
    Brisbane QLD
    So it does have to be coded by an auto electrician with the Scantool?
    Yes with suitable diagnostics tools like vcds, obd11 etc
    Sent from my SM-G960F using Tapatalk
    Oct 2015
    Brisbane QLD
    Do you know of any workshops who overhaul these ABS units?
