Results 1 to 5 of 5
Thread: Amarok V6 Check Engine Issues
    Aug 2023
    I have a V6 Amarok with a recurring but intermittent check engine light.
    I have scanned the error codes and get two different codes depending on which tool I use.
    Using OBD11 I get an error code 0538 and under voltage issues with various exhaust gas temp sensors etc as well as a Central Electronics error of open circuit.
    Using Carly I get an 021A message which seems to indicate an injector issue (but is probably triggered by the under voltage errors as per OBD11 above).
    I have checked every fuse that I think may be at fault and found nothing. Checked the battery and charging rate and all seems fine in that area. I'm not sure where else to start looking.
    Has anyone else had this issue and if so, what is the cause.
    Thanks in advance if anyone can offer suggestions or solutions.
    Darryl
    Mornington Peninsula, VIC
    If you can upload the error log from OBD11, it will help pinpoint the issue.
    Use the app's email function, to send it to yourself, then you can upload it here.
    00538 - Reference Voltage : Signal too small, is a general error that could be triggered on many modules.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Aug 2023
    Quote Originally Posted by MIG View Post
    Here are the two fault logs;
    OBDeleven vehicle history log
    Date: 2023-08-17 19:03:16
    VIN: WV1ZZZ2HZHH014936
    Car: VW Amarok V6
    Year: 2017
    Body type: UNKNOWN
    Engine: DDXC kW ( hp) l
    Mileage: 175190 km
    01 Engine
    System description: 3.0l V6 TDI
    Software number: 2H6907311E
    Software version: 0001
    Hardware number: 059907309J
    Hardware version: X21
    Faults:
    P220100 - NOx Sensor Circuit Range/Performance Bank 1 Sensor 1
    static
    Priority - 2
    Malfunction frequency counter - 1
    Unlearning counter - 255
    km-Mileage - 175062 km
    Engine speed - 1832.00 1/min
    Normed load value - 39.6 %
    Vehicle speed - 103 km/h
    Coolant temperature - 95 °C
    Intake air temperature - 22 °C
    Ambient air pressure - 1010 mbar
    Voltage terminal 30 - 12.760 V
    Dynamic environmental data - 20962810261A85150D008C150E009515260287132F20001139 060816250B41
    date - 2072-12-23 09:14:02
    static
    Priority - 2
    P103300 - NOX Sensor
    Signal too low
    static
    Priority - 2
    km-Mileage - 175056 km
    Engine speed - 1364.00 1/min
    Normed load value - 60.0 %
    Vehicle speed - 75 km/h
    Coolant temperature - 91 °C
    Intake air temperature - 19 °C
    Voltage terminal 30 - 13.060 V
    Dynamic environmental data - 20962810261752150D0092150E008D152604D6132F1FFE1139 08E716250B3C
    date - 2072-12-23 09:10:41
    2nd Fault Log for code 0538
    Date: 2023-08-17 19:04:01
    Car: VW Amarok V6
    Year: 2017
    Body type: UNKNOWN
    Mileage: 175190 km
    09 Central Electrics
    System description: BCM PQ25 MMI4
    Software number: 7E0937089A
    Software version: 0744
    Hardware number: 7E0937089
    Hardware version: H81
    Faults:
    00538 - Reference voltage
    static
    priority - 3
    frequencyCounter - 2
    drivingCycle - 77
    km-Mileage - 175045 km
    Not sure where to go from here to sort the issue. Any help would be appreciated.
    Thanks
    Pacific Paradise QLD
    Best shift this to the AMAROK forum This is the RULES forum as its labelled
    Thread moved to Amarok section. Sounds like you have a failed NOX sensor. Not entirely uncommon. Genuine VW NoX Sensor for Volkswagen Amarok 3.0 TDI Engines
