Results 1 to 7 of 7
Thread: Need some help with MSFW retrofit in Amarok
    Sep 2023
    Namibia
    Hey all, new here!
    I replaced my crappy plastic trendline steering on my 2012 Amarok wheel with a MFSW from Jetta 6 with buttons. Now I'm trying to get the radio control buttons to work, but having no luck.
    Added 12v+ to pin 9 from pin 15 on the headlight module
    Added wire from pin 10 to purple/white cable in kick panel
    Buttons aren't lighting up and obviously can't control anything
    I have a weird module inside the steering wheel that I haven't seen in other peoples wheels, the button modules connect to it via ribbon cable, but there's an empty plug there, what do I do with this? Could it be the reason nothing is working?
    I also have an after market Amarok specific headunit, but surely illumination should work at the very least.
    I have used OBDEleven long coding to enable MFSW.
    Your help would be greatly appreciated!
    Sep 2023
    Namibia
    Here's the module in my steering wheel
    Attachment 55452
    Mornington Peninsula, VIC
    Your images don’t look to be working.
    Would need part numbers and a vcds or obd11 scan to be able to see what going on.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Sep 2023
    Namibia
    Quote Originally Posted by MIG View Post
    Ahhhh crap, let me reupload.
    What do you require from OBD11?
    Need some help with MSFW retrofit in Amarok-steeringwheel-jpg
    Sep 2023
    Namibia
    I think I figured it out. I bought the wheel without airbag and used my previous one. It doesn't have the black plug that goes into that module in the picture. Is that why it's not working perhaps?
    I can get the original airbag for this wheel if it could resolve the issue?
    Sep 2023
    Namibia
    Bump!!!
    Sep 2023
    Namibia
    So I bought a new harness. Illumination instantly worked and strangely, the MFD buttons, even though I didn't pull in the additional wires for it (only pin 9 and 10 on the slip ring)
    The left buttons still don't operate anything though and I'm 100% convinced it has to do with the aftermarket radio.
    Any pointers?
