When you indicate and the brake, tail lamp and reverse light all flash at the same time.
Printable View
you know you drive a mk1 when you get compliments from homeless guys and security guards :P
you know you drive a mk1 when you feel like your spine is about collapse, after driving for 5 minutes, when you accidentally set your front shocks (koni yellow) to the firmest setting
You know when you drive a GLD when you have to "shake n bake" to overtake
when you've sold your MK1, watched it taken away on the back of a truck and contact the new owner every day to see if it arrived safely.
You take corners on three wheels, and V8's can't catch you.
When your stuck in traffic and the truck next to you side exit exhaust directs straight into your passenger window :(
You pull into your drive way after work to grab things and pick up some friends just as you park the stereo turns off and won't turn on again..
When going from a 4x4 daily to finally driving the mk1 for the first since buying it and fixing it.
little tin can on wheels... coilovers and leaking exhaust.
Seems i need to do more work to it
