A Mk1 GTI rad is fine for pretty much anything - especially with little, to no, accessories on the motor![]()
what radiator should i get for the mk1 to keep it cooler as i have a new engine for it?
is the diesel radiator the better one?
Is a mk2 gti rad much bigger or better? curious to this myself.
Something you could do is get a twin fan shroud, not sure how much difference they make though.
I used an Audi 80 1993 Model Radiator and twin thermofans for my Mk1. Its almost perfect sizewize and contains heaps more coolant than a Mk1 rad.
I rarely saw any Mk1s overheat due to small radiators, even the standard ones work fine if the rest of the cooling system is up to scratch.
I squeezed a twin fan Cordoba radiator into my MK I, but then I also put the cordoba motor in there too!
Pete
the top fill radiator is the same size as the gti/diesel ratiator too, its just that the gti/diesel radiators have separate expansion tank to make it a proper air free system and so is a little more effective...
and so yes, the diesel and gti radiators are the same.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
