Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Swapping the 1.6L for a 1.8L and 5 speed
    Sep 2009
    Chillaxing in Tas
    Hey all
    Going to be swapping in a rebuilt 1.8L and a 5 speed box into my MK1 in a few weeks. anything i should look out for?
    Also are the 1.6L cam wheel same as the 1.8L?
    and how did ya go about blocking the 4 holes above the inlet manifold?
    Im guessing they for the K-Jet?
    Regards
    Dan
    <space for rent>
    Jun 2008
    Hobart, TAS
    if memory serves me correct, the four holes are for efi, k-jet uses just one injection point much like a carby.
    someone correct me if i'm wrong..
    there are plenty of stories about conversions are, try using the search function, or trawling the conversions section.
    good luck with it mate.
    1979 Mk1 Golf GTi
    1994 Mk3 Golf VR6
    Oakleigh VIC
    Quote Originally Posted by GRN_VAGN View Post
    Yes, and so is the timing belt.
    Yep, they're the injector holders, they should unscrew. You can drop a coin down the hole and screw the holder back into place to block them off or beetle gearbox drain plugs screw in there too.
    You can also leave a set of injectors in there or fill them up with Devcon.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Sep 2009
    Chillaxing in Tas
    Cheers pete, ill have a looky soon, gotta finish the 18RG motor first, then drop that in the celica. then ill tend to the golf
    And cheers for the tip on the coin
    <space for rent>
    Oakleigh VIC
    We did this trick on GoLfMans 1800. I think it was 10cent pieces we used.
    If your car has the plastic insulator on the end of the injector holder you'll need to remove those. Sometimes they come out with the holder other times they get stuck in the head. It's best to do the work with the manifold off so you can get at the underside of the injector holes if you need to.
    We used a little bit of Permatex blue RTV sealant. (Silicone) on the coins to ensure a good seal.
    On the later heads there's an air gallery as well that connects to vacuum. There's a small plastic fitting between inlet ports 3 & 4. Using the coins blocks this off internally but I'd block the fitting off too just to be sure.
    This air gallery draws air from around the injectors to keep them cool it'll only be on the motors with injector insulators.
    Pete
    7? MK1 Caddy
    12 Amarok
    Gosford Central Coast NSW
    Quote Originally Posted by SpeciP3 View Post
    correction: k-jet uses a total of 5 injectors, one in each port in the head (the holes described) and a single cold start injector in the manifold plenum.
    there is a single point injection system that was fitted to the 1.8L non-intereference motors (ADY and ADZ, and a few others i think) which is found on some mk3 CL's, SEAT cordoba's etc.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2007
    Eastern Suburbs Melbourne
    I actually think it was 5 cent pieces wasn't it pete?
    Make sure you have matching CV's for the gearbox.
    4 speed ones are 90mm, 5 speed ones are 100mm.
    i like volkswagens
    Sep 2009
    Chillaxing in Tas
    ooo didnt know that, cheers Jarred.
    By CV, im guessing the bit that joins to either side of the gearbox?
    <space for rent>
    Jun 2007
    yea, but the part actually on the Driveshaft.
    i like volkswagens
    Sep 2009
    Chillaxing in Tas
    so what actuall part is different? the CV on the end of the shaft? can the large CV be put on current shaft and used that way?
    <space for rent>
