Results 1 to 10 of 13
Thread: Unserviceable '93 Golf Cabriolet!
    Jun 2007
    Country Victoria
    A wheel alignment and balance was due on the Golf. Simple, book it in, drop the car off, pay the bill, drive home. Easy as that...
    Computer said "Noooo" Apparently my car is the only one they have ever seen with a "Nonadjustable solid left hand tie rod" Their computer wheel alignment system which can detect issues within half a mm is unable to deal with a "European import".
    It got worse. I was told "This vehicle could never be adjusted properly" and "I have been ripped off by every person that had ever adjusted the alignment'.
    I have never had alignment issue with the car. Tyres wear evenly.
    Of course the car now drives - badly. Pulls to the right and "floats" at highway speed.
    They have had two attempts to correct this, but have no idea on what to do.
    Can someone please tell me how to adjust the alignment? I can then pass this on to the tyre shop so they can fix it. Or better still point me in the direction of a workshop that understands MK1 Golfs.
    Thanks
    Michael
    Oakleigh VIC
    They're lying to you. (or more likely, just ignorant)
    All Mk 1 golfs left the factory that way.
    Procedure would be to point the wheel with the fixed tie rod in the right direction, lock the steering wheel then adjust the other. Once that's done, if the steering wheel is out of whack you have to pull it off and move it round a couple of splines.
    The fixed tie rod can be replaced with an adjustable one left and right are the same. A lot of Golfs have had this done.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Jun 2007
    Eastern Suburbs Melbourne
    I've always done it the same way Pete described.
    That shop sounds incompetent to me! Surely someone who does wheel alignments for a living could have figured this out!
    i like volkswagens
    Dec 2007
    Perth, WA. *YAWN*...
    Every single "tyre shop" i've been to to do an alignment has brought it back worse, or with the steering wheel out of whack.
    They are almost all useless clowns that take one look at a European car and immediately put up a wall of ignorance.
    Maybe try a proper race type shop who's had some experience with older porsche's etc???
    Oakleigh VIC
    You could also learn to do it yourself.
    It's basic geometry. All you need is a roll of string and tape measure.
    It'll take a little time but you can be just as accurate as the computer alignment places.
    7? MK1 Caddy
    12 Amarok
    Jun 2007
    Country Victoria
    Thanks Peter
    That what I suggested to them. As the rear wheels wheels are nonadjustable (I think?)- align the left front wheel straight with the left rear wheel, and then adjust the right tie rod. I was advised that this will cause extreme tyre wear.
    They will no longer remove steering wheels due to Airbags and stereo controls etc. (I don't have these). So now my steering wheel is angled to the left!
    I think I will ask "Bob" for my money back. And then find an older workshop.
    Michael
    Oct 2010
    Melbourne Victoria
    Take it too a Specific VW Workshop.
    Failing that have a go by yourself as the guys above have mentioned - if you need a workshop that knows MK1's inside and out
    VOLKWERKE in melbourne. Thats where i'll be taking mine
    Oakleigh VIC
    Yeah, those alignment places are half way houses for mechanics that can't actually fix cars.
    The joint will be owned by a businessman who bought into the franchise and hires 16 year old apprentices to work on your car.
    Same sort of business model as Subway and McDonalds.
    I went to one once and had to train them on how to adjust camber, they'd never done it before!
    If you can get there, TrackSide Tyres know how to align MK1 Golfs. There's about 4 MK1 racecars being looked after by Craig. Trackside Race and Rally Tyres Service
    7? MK1 Caddy
    12 Amarok
    Jun 2007
    Country Victoria
    Thanks everyone
    That's the information I need!
    Michael
    Mar 2007
    South Brisbane
    Thats how i do mine as already stated most of these places hire young guys and don't bother training them properly. I know alot of tire shops don't like to do alignments because 1 they take to long, 2 if its no done right the customer will be back to complain so its risky and spin you some crap to get out of it.
