really looking great Andrew! :D dam neat
Printable View
dam son! Really getting stuck into it :D Looks awesome
Shooot merry trucker Christmas to you.
NAISE!!!
keep it up.
Thanks guys, its overwhelming how much still needs to be done hahaha, but it is getting there :cool: I do all the work myself so its a long process .
Does anyone have a wiring diagram for a 3 wire vw alternator???
oil cooler mounted.
http://img834.imageshack.us/img834/9091/17122011350.jpg
Does this help??
http://www.vwwatercooled.com.au/foru...58a364d7-1.jpg
Alternator being C
Battery A
Starter B
Coil N
It does do you have a better quality image?
Undercarriage..........
http://img27.imageshack.us/img27/2351/28122011387.jpg
Wow, great stuff mate!
Which alt do you have? - anyway they are basically all the same - the later ones have a b+ for the charge light and a w for tach signal on some cars. both are pretty safe i.e if you wire up the w to the charge light you wont cause any problems. You wont need the w terminal cos you'll get tach signal from the ignition.
So basically all you need is to connect the big terminal to the battery +, earth the alt body well and one of the little plugs goes to the charge light circuit on the dash.
Thanks gldgti, makes sense to me now i wired it up a couple years ago just needed my memory refreshed Ive basically binned the stock wiring loom and opted for a universal hotrod wiring loom and fuse box less complicated :cool: Ill post pix as i start the wiring in the mean time fitted the front brakes.
http://img440.imageshack.us/img440/7278/29122011390.jpg
http://img210.imageshack.us/img210/4122/29122011391.jpg
