Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Possible engine swaps?
    Nov 2010
    Kingston, Tas.
    Alrighty, need some advice for a new donk to go in the Mk1. Need something that will go in relatively easy, don't want to stuff around with custom mounts and stuff. Something injected would be good, don't need loads of power but enough to make things interesting.
    How tricky would it be to get something like a 16v 1.8/2.0 in there? Any other suggestions?
    Thanks in advance!
    Oakleigh VIC
    Have you had a look at the conversions thread? Lots of good ideas in there.
    Conversions
    Best bang for buck is the 1800s out of the MK3 CL or Seat Cordobas. Very asy install and GTI power.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Feb 2010
    go for a Suzuki Hyabusa Turbo.
    YouTube - Mk1 Golf Hayabusa Turbo!
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Jul 2005
    Newcastle, NSW
    A mk3 as suggested would be good. But EFI means rewiring the ECU in etc.
    16V early are KJet which would be too much effort to convert.
    Later ABF 16v need custom work as they are taller than the earlier 16v engines.
    Mar 2007
    South Brisbane
    How much you have to spend? that will determine what you can do
    Sep 2009
    Chillaxing in Tas
    i got a 1800 basically ready to drop in and drive.
    Im up north of tassy, check out my for sale topics
    <space for rent>
    Gold Coast
    What about something a bit different. A 1.4 16V from a 6N Polo?
    Jun 2007
    Eastern Suburbs Melbourne
    What's your budget?
    What's your goal?
    What's your skill level?
    i like volkswagens
    Nov 2010
    Kingston, Tas.
    Only have <$4000 to spend, thinking that might not be enough for 16v/ injection. What does everyone think of an 8v 1.8? Any performance parts available for them? Main reason for going newer is to get a 5spd box, any suggestions for getting a 5spd onto the stock (or 1800) motor?
    Sep 2009
    Chillaxing in Tas
    5 speed on a 1800 is easy,
    just put a wanted to buy add for one, or PM Matt (golf loon) at Camden GTi... sure he has a few?
    the 1800's go well, slap a weber or two on, bigger cam and a good clutch, Headers and exhaust and its more then enough power to get you in trouble
    Maybe even a 2L from a mk3 would be good, better if you could find a whole car as a donor...
    <space for rent>
