take door trim off
Drill out the Pop rivet holding the metal runner bit that's between quarter window and main window.
Under screw under rubber sill on top of door. you can now remove that metal bit.
Pull the quarter window with rubber still attached towards back of car.
Clean the metal and whatever else.
Put new non opening rubber around quarter glass, slide it back in.
Reverse said procedure, you can pop rivet the metal bit back in, or use a screw like i did
