Results 11 to 20 of 24
Thread: Battery in boot
    Apr 2011
    Melbourne, VIC
    Battery in boot
    You do need a non-gassing battery if it is to be installed inside the vehicle. Either an AGM or a sealed maintenance-free unit with vent to outside (similar to Holden VE series) is acceptable and currently legal. We fit these in a daily basis.
    May 2012
    Tullamarine
    Quote Originally Posted by DonJuan View Post
    Might not make any didference but From the labels on the batterry I've got a delkor 22FR-680 which also indicated that its a sealed MF battery, the information I gained from the young salesman wasnt accurate, he assumed that its a universal battery which could be stored inside or in the engine bay.
    I might also contact vicroads and explain what I'm doing so I can get a accurate answer which may comply with the standards!
    MK1, 1976 golfLS, 4 door (SOLD! Will be missed)
    MK1, 1980 golfGLD, 4 door (1.8l, 8v, 5 speed)
    Apr 2011
    Melbourne, VIC
    Battery in boot
    Quote Originally Posted by 5teve View Post
    I might also contact vicroads and explain what I'm doing so I can get a better accutare answer which may comply with the standards!
    The Delkor should have recessed terminals and have a hole at one end. You can then get a long thin tube to plug into the hole and the other ends vents to outside via a small hole in the underside of the body in your boot space. There will also bd a hole on the other end which will need a plug. So it will work if properly vented. Any doubts, go see your local Battery World.
    Jan 2009
    blankedy
    Great info Don Juan, love to know more about it.
    Feb 2009
    Please Enter Location
    Too much trouble for my liking whats wrong with the original position under the bonnet ?
    Jan 2009
    blankedy
    It can make space for pod filters, other engine components, tidy up the engine bay if you like to make it look pretty or help with evening out the weight distribution.
    I'd be doing it for weight distribution personally.
    Pacific Paradise QLD
    A very sensible suggestion and the only place to get an absolutely correct answer
    May 2012
    Tullamarine
    Thought it would be a good idea to relocate the battery, Also wanted to be a tad different from the other mk1'ers and position the battery in the boot just to make the engine bay look a bit tidy!
    May 2012
    Tullamarine
    Other engine components??? Hmmmmmm sounds very interesting! **thinking **
    May 2011
    Albury, NSW
    Glad someone started this thread - had this planned for my Cabby
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
